Date/Time: Fri, 11 Sep 2026 08:50:55 +0000
Add Study/Price Overlay - how can i get this secondary instrument on its own y-axis?
View Count: 1584
| [2016-01-15 05:41:18] |
| User71961 - Posts: 144 |
say i want to chart /ES vs /ZN in the same chart window. In my example, ES is the main instrument for the chart...and ZN is the Study/Price Overlay instrument ES(S&P futures) and ZN(10yr treasury futures) have completely different price scales. I need Sierra Chart to have a separate y-axis for each secondary instrument. Otherwise, there is no easy way to compare the different securities. I'm expecting Sierra Chart to set the secondary y-axis to auto-scale to fit the data for this secondary instrument. I don't see an option to do this in the Study/Price Overlay settings. Help? |
| [2016-01-15 05:57:54] |
Did you want to display the symbols both in the same Chart Region on the chart or in separate Chart Regions?
| [2016-01-15 14:37:03] |
yes, i want them to both display in the same chart region....aka...overlayed. this is why i need the 2nd security to have its own y-axis.
Date Time Of Last Edit: 2016-01-15 18:25:51
| [2016-01-15 15:12:34] |
ideally...in the settings of the Study/Price Overlay, there is a choice to use the primary y-axis, or an independent secondary y-axis, and also a choice to place the secondary y-axis on the right or left side of the chart.
| [2016-01-16 01:16:23] |
You need to set the Study/Price Overlay study to use an Independent Scale Range. Follow the instructions here for this: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowStudy And enable the Left Side Scale in Chart >> Chart Settings: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#UseLeftSideScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-16 01:17:00
