Date/Time: Sat, 28 Dec 2024 16:09:28 +0000
Intraday data from SC Historical Data
View Count: 701
[2016-01-14 22:11:57] |
User19107 - Posts: 7 |
How do I download the 3 years of intraday data while using SC Historical data under Data/Trade Service when the latest available Symbol is ESU15? I need to start with ESH2013?
[2016-01-15 22:09:13] |
In your case you need to set the Service in Sierra Chart to AMP/TTNet and use the symbols for that service. For long-term futures charts, use the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
