Date/Time: Sat, 28 Dec 2024 15:49:37 +0000
Overlay price study help
View Count: 839
[2016-01-14 21:54:35] |
User66360 - Posts: 81 |
Id like to have two different time-frames with the overlay study. Is this possible? I'd like to have for example, a 60 min with a 50,000 volume bar overlay on it. For one symbol, ES, YM, CL, etc. Please help. thank you I cant figure how to have one time based and the overlay volume based? They both change together? |
[2016-01-15 03:46:08] |
Refer to this page for instructions: http://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-15 13:07:12] |
i read all through that and didnt find it. Please be more specific. thank you
[2016-01-15 20:53:12] |
We have went through the instructions on this page: http://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#UsingTheStudyPriceOverlayStudy We have clarified some of the steps, but let us know where specifically you are having a problem or question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
