Date/Time: Sat, 28 Dec 2024 07:37:49 +0000
How to add a permanent text/note on the chart?
View Count: 2624
[2016-01-14 19:10:30] |
jagoankita - Posts: 24 |
Hi, I would like to know how to add a permanent text/note on the chart that won't move during scrolling. The text/note at the chart title or not are acceptable for me as long as it appears all the time permanently. Thanks. |
[2016-01-15 03:51:44] |
This can be done using the Tools >> Stationary Text tool: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#TypeText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
