Date/Time: Sat, 28 Dec 2024 07:52:20 +0000
Moving the chart with the hand
View Count: 723
[2016-01-14 18:18:10] |
User623839 - Posts: 108 |
I can use the hand to move the chart from side to side but how do I switch on the function to move the chart up and down with the hand also?
[2016-01-14 18:29:13] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-15 03:52:05] |
Nice thanks!
