Date/Time: Mon, 28 Oct 2024 08:57:50 +0000
how do I set the chart for the SP E-mini to show vertical line for eve session?
View Count: 660
[2016-01-13 21:14:09] |
Jimmy K - Posts: 10 |
how do I set the chart for the SP E-mini to show vertical line for eve session? I have been looking for this feature?? Is it available on Sierra Charts? |
[2016-01-14 02:18:45] |
This can be done through the Vertical Grid: http://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#Vgrid You will need to set the Evening Session Times: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-14 02:19:31
