Date/Time: Sat, 04 Jul 2026 05:19:30 +0000
I'm still waiting to reconnect to GAIN/OEC datafeed
View Count: 1021
[2016-01-13 20:29:30]
User88614 - Posts: 6
Hi
could you help me? Today I can not connect to GAIN/OEC Datafeed, I'm still waiting to reconnect. Tomorrow evening was all OK and my connection works good
Where is the problem?
my version of SCH je 1354
let me know
Míra
[2016-01-13 20:37:22]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-01-13 20:41:04]
HI
thank fo quick reply, I provide copy my message log
Software version: 1354 | 2016-01-13 21:16:36
Uses New Spreadsheets | 2016-01-13 21:16:36
Usage end date: 2016-02-11 | 2016-01-13 21:16:36
Enabled for: Advanced Features. | 2016-01-13 21:16:36
Enabled for: Advanced Features 2. | 2016-01-13 21:16:36
Enabled for: Sierra Chart Historical Data Service. | 2016-01-13 21:16:36
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-13 21:16:36
Current selected Data/Trading service: GAIN Capital/OEC | 2016-01-13 21:16:36
Chart Update Interval: 500 | 2016-01-13 21:16:36
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-01-13 21:16:36
2016-01-13 21:16:36 Local computer time | 2016-01-13 21:16:36
2016-01-13 20:16:36 Local computer time in UTC | 2016-01-13 21:16:36
2016-01-13 21:16:36 Local computer time in SC Time Zone | 2016-01-13 21:16:36
2016-01-13 20:16:54 Server time in UTC | 2016-01-13 21:16:36
Local computer UTC time and Server UTC time difference: 18 seconds. | 2016-01-13 21:16:36
Program path: C:\SierraChart\ | 2016-01-13 21:16:36
Data Files path: C:\SierraChart\Data\ | 2016-01-13 21:16:36
OS Version Number: 6.2 | 2016-01-13 21:16:36
Locale Information: C | 2016-01-13 21:16:36
Checking for new symbol settings for oec | 2016-01-13 21:16:36
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-13 21:16:36
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-01-13 21:16:36
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-01-13 21:16:36
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-01-13 21:16:36
Requesting symbol settings for oec. Overwrite = on. | 2016-01-13 21:16:36
Symbol settings received. | 2016-01-13 21:16:37
Processed received symbol settings | 2016-01-13 21:16:37
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:16:41
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:16:41
GainCapital FIX Trading socket (4) | Connected. | 2016-01-13 21:16:41
GainCapital FIX Trading socket (4) | Starting TLS 1.2 connection. | 2016-01-13 21:16:41
GainCapital FIX Trading socket (4) | SSL connection established. | 2016-01-13 21:16:42
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:16:42
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-01-13 21:16:42
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:16:42
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-01-13 21:16:42
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:16:42
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:16:42
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:16:42
GainCapital FAST Data socket (5) | Connected. | 2016-01-13 21:16:42
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:16:42
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:16:42
GainCapital FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:16:42
GainCapital FAST Data: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:16:42
GainCapital FAST Data socket (5) | Shutdown and closed. | 2016-01-13 21:16:42
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:16:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:16:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:16:42
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:16:42
GainCapital FIX Trading: DisconnectFIX called. | 2016-01-13 21:16:42
GainCapital FIX Trading: Sending a Logout message. | 2016-01-13 21:16:42
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:16:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:16:42
GainCapital FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:16:43
GainCapital FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:16:43
GainCapital FIX Trading socket (4) | SSL has been shut down. | 2016-01-13 21:16:43
GainCapital FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:16:43
GainCapital FIX Trading socket (4) | Shutdown and closed. | 2016-01-13 21:16:43
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:16:43
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:14
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:14
GainCapital FIX Trading socket (44) | Connected. | 2016-01-13 21:18:14
GainCapital FIX Trading socket (44) | Starting TLS 1.2 connection. | 2016-01-13 21:18:14
GainCapital FIX Trading socket (44) | SSL connection established. | 2016-01-13 21:18:14
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:14
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:14
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:14
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:14
GainCapital FAST Data socket (45) | Connected. | 2016-01-13 21:18:15
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:18:15
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:15
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:15
GainCapital FIX Trading socket (44) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:15
GainCapital FIX Trading socket (44) | SSL has been shut down. | 2016-01-13 21:18:15
GainCapital FIX Trading socket (44) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:15
GainCapital FIX Trading socket (44) | Shutdown and closed. | 2016-01-13 21:18:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:15
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:15
GainCapital FAST Data: Sending a Logout message. | 2016-01-13 21:18:15
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:15
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:15
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:18:15
GainCapital FAST Data socket (45) | Closed. No error. | 2016-01-13 21:18:15
GainCapital FAST Data socket (45) | Shutdown and closed. | 2016-01-13 21:18:15
GainCapital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-01-13 21:18:15
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:15
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:18
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:18
GainCapital FIX Trading socket (46) | Connected. | 2016-01-13 21:18:18
GainCapital FIX Trading socket (46) | Starting TLS 1.2 connection. | 2016-01-13 21:18:18
GainCapital FIX Trading socket (46) | SSL connection established. | 2016-01-13 21:18:18
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:18
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:19
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:19
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:19
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:19
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:19
GainCapital FIX Trading socket (46) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:19
GainCapital FIX Trading socket (46) | SSL has been shut down. | 2016-01-13 21:18:19
GainCapital FIX Trading socket (46) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:19
GainCapital FIX Trading socket (46) | Shutdown and closed. | 2016-01-13 21:18:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:19
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:19
GainCapital FAST Data socket (47) | Shutdown and closed. | 2016-01-13 21:18:19
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:18:19
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:19
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:19
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:22
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:22
GainCapital FIX Trading socket (48) | Connected. | 2016-01-13 21:18:22
GainCapital FIX Trading socket (48) | Starting TLS 1.2 connection. | 2016-01-13 21:18:22
GainCapital FIX Trading socket (48) | SSL connection established. | 2016-01-13 21:18:23
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:23
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:23
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:23
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:23
GainCapital FIX Trading: Received a Logout message. | 2016-01-13 21:18:23
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:23
GainCapital FIX Trading socket (48) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:23
GainCapital FIX Trading socket (48) | SSL has been shut down. | 2016-01-13 21:18:23
GainCapital FIX Trading socket (48) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:23
GainCapital FIX Trading socket (48) | Shutdown and closed. | 2016-01-13 21:18:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:23
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:23
GainCapital FAST Data socket (49) | Shutdown and closed. | 2016-01-13 21:18:23
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:18:23
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:23
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:23
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:26
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:26
GainCapital FIX Trading socket (50) | Connected. | 2016-01-13 21:18:26
GainCapital FIX Trading socket (50) | Starting TLS 1.2 connection. | 2016-01-13 21:18:26
GainCapital FIX Trading socket (50) | SSL connection established. | 2016-01-13 21:18:26
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:27
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:27
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:27
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:27
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:27
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:27
GainCapital FIX Trading socket (50) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:27
GainCapital FIX Trading socket (50) | SSL has been shut down. | 2016-01-13 21:18:27
GainCapital FIX Trading socket (50) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:27
GainCapital FIX Trading socket (50) | Shutdown and closed. | 2016-01-13 21:18:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:27
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:27
GainCapital FAST Data socket (51) | Shutdown and closed. | 2016-01-13 21:18:27
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:18:27
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:27
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:27
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:30
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:30
GainCapital FIX Trading socket (52) | Connected. | 2016-01-13 21:18:30
GainCapital FIX Trading socket (52) | Starting TLS 1.2 connection. | 2016-01-13 21:18:30
GainCapital FIX Trading socket (52) | SSL connection established. | 2016-01-13 21:18:30
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:31
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:31
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:31
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:31
GainCapital FAST Data socket (53) | Connected. | 2016-01-13 21:18:31
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:18:31
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:18:31
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:31
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:31
GainCapital FIX Trading socket (52) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:31
GainCapital FIX Trading socket (52) | SSL has been shut down. | 2016-01-13 21:18:31
GainCapital FIX Trading socket (52) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:31
GainCapital FIX Trading socket (52) | Shutdown and closed. | 2016-01-13 21:18:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:31
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:31
GainCapital FAST Data: Sending a Logout message. | 2016-01-13 21:18:31
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:31
GainCapital FAST Data: Received a Logout message. Text = Locked | 2016-01-13 21:18:32
GainCapital FAST Data socket (53) | Shutdown and closed. | 2016-01-13 21:18:32
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:18:32
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:32
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:34
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:34
GainCapital FIX Trading socket (54) | Connected. | 2016-01-13 21:18:35
GainCapital FIX Trading socket (54) | Starting TLS 1.2 connection. | 2016-01-13 21:18:35
GainCapital FIX Trading socket (54) | SSL connection established. | 2016-01-13 21:18:35
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:35
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:36
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:36
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:36
GainCapital FAST Data socket (55) | Connected. | 2016-01-13 21:18:36
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:18:36
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:18:36
GainCapital FAST Data: Received a Logout message. Text = Locked | 2016-01-13 21:18:36
GainCapital FAST Data: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:36
GainCapital FAST Data socket (55) | Shutdown and closed. | 2016-01-13 21:18:36
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:18:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:36
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:36
GainCapital FIX Trading: DisconnectFIX called. | 2016-01-13 21:18:36
GainCapital FIX Trading: Sending a Logout message. | 2016-01-13 21:18:36
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:36
GainCapital FIX Trading: Received a Logout message. | 2016-01-13 21:18:36
GainCapital FIX Trading socket (54) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:36
GainCapital FIX Trading socket (54) | SSL has been shut down. | 2016-01-13 21:18:36
GainCapital FIX Trading socket (54) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:36
GainCapital FIX Trading socket (54) | Shutdown and closed. | 2016-01-13 21:18:36
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:36
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:39
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:39
GainCapital FIX Trading socket (57) | Connected. | 2016-01-13 21:18:39
GainCapital FIX Trading socket (57) | Starting TLS 1.2 connection. | 2016-01-13 21:18:39
GainCapital FIX Trading socket (57) | SSL connection established. | 2016-01-13 21:18:40
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:40
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:40
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:40
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:40
GainCapital FAST Data socket (58) | Connected. | 2016-01-13 21:18:40
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:18:40
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:18:41
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:41
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:41
GainCapital FIX Trading socket (57) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:41
GainCapital FIX Trading socket (57) | SSL has been shut down. | 2016-01-13 21:18:41
GainCapital FIX Trading socket (57) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:41
GainCapital FIX Trading socket (57) | Shutdown and closed. | 2016-01-13 21:18:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:41
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:41
GainCapital FAST Data: Sending a Logout message. | 2016-01-13 21:18:41
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:41
GainCapital FAST Data: Received a Logout message. Text = Locked | 2016-01-13 21:18:41
GainCapital FAST Data socket (58) | Shutdown and closed. | 2016-01-13 21:18:41
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:18:41
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:41
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:44
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:44
GainCapital FIX Trading socket (59) | Connected. | 2016-01-13 21:18:44
GainCapital FIX Trading socket (59) | Starting TLS 1.2 connection. | 2016-01-13 21:18:44
GainCapital FIX Trading socket (59) | SSL connection established. | 2016-01-13 21:18:44
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:44
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:45
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:45
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:45
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:45
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:45
GainCapital FIX Trading socket (59) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:45
GainCapital FIX Trading socket (59) | SSL has been shut down. | 2016-01-13 21:18:45
GainCapital FIX Trading socket (59) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:45
GainCapital FIX Trading socket (59) | Shutdown and closed. | 2016-01-13 21:18:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:45
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:45
GainCapital FAST Data socket (60) | Shutdown and closed. | 2016-01-13 21:18:45
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:18:45
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:45
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:45
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:48
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:48
GainCapital FIX Trading socket (61) | Connected. | 2016-01-13 21:18:48
GainCapital FIX Trading socket (61) | Starting TLS 1.2 connection. | 2016-01-13 21:18:48
GainCapital FIX Trading socket (61) | SSL connection established. | 2016-01-13 21:18:48
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:49
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:49
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:49
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:49
GainCapital FIX Trading: Received a Logout message. | 2016-01-13 21:18:49
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:49
GainCapital FIX Trading socket (61) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:49
GainCapital FIX Trading socket (61) | SSL has been shut down. | 2016-01-13 21:18:49
GainCapital FIX Trading socket (61) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:49
GainCapital FIX Trading socket (61) | Shutdown and closed. | 2016-01-13 21:18:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:49
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:49
GainCapital FAST Data socket (62) | Shutdown and closed. | 2016-01-13 21:18:49
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:18:49
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:49
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:49
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:18:52
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:52
GainCapital FIX Trading socket (63) | Connected. | 2016-01-13 21:18:52
GainCapital FIX Trading socket (63) | Starting TLS 1.2 connection. | 2016-01-13 21:18:52
GainCapital FIX Trading socket (63) | SSL connection established. | 2016-01-13 21:18:52
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:18:53
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:18:53
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:18:53
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:18:53
GainCapital FAST Data socket (64) | Connected. | 2016-01-13 21:18:53
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:18:53
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:18:53
GainCapital FAST Data: Received a Logout message. Text = Locked | 2016-01-13 21:18:54
GainCapital FAST Data: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:18:54
GainCapital FAST Data socket (64) | Shutdown and closed. | 2016-01-13 21:18:54
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:18:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:18:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:18:54
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:18:54
GainCapital FIX Trading: DisconnectFIX called. | 2016-01-13 21:18:54
GainCapital FIX Trading: Sending a Logout message. | 2016-01-13 21:18:54
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:18:54
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:18:54
GainCapital FIX Trading: Received a Logout message. Text = Locked | 2016-01-13 21:18:54
GainCapital FIX Trading socket (63) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:18:54
GainCapital FIX Trading socket (63) | SSL has been shut down. | 2016-01-13 21:18:54
GainCapital FIX Trading socket (63) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:18:54
GainCapital FIX Trading socket (63) | Shutdown and closed. | 2016-01-13 21:18:54
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:18:54
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:21:54
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:21:54
GainCapital FIX Trading socket (66) | Connected. | 2016-01-13 21:21:54
GainCapital FIX Trading socket (66) | Starting TLS 1.2 connection. | 2016-01-13 21:21:54
GainCapital FIX Trading socket (66) | SSL connection established. | 2016-01-13 21:21:54
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:21:54
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:21:54
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:21:54
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:21:54
GainCapital FAST Data socket (67) | Connected. | 2016-01-13 21:21:55
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:21:55
GainCapital FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:21:55
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:21:55
GainCapital FIX Trading socket (66) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:21:55
GainCapital FIX Trading socket (66) | SSL has been shut down. | 2016-01-13 21:21:55
GainCapital FIX Trading socket (66) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:21:55
GainCapital FIX Trading socket (66) | Shutdown and closed. | 2016-01-13 21:21:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:21:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:21:55
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:21:55
GainCapital FAST Data: Sending a Logout message. | 2016-01-13 21:21:55
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:21:55
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:21:55
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:21:55
GainCapital FAST Data socket (67) | Closed. No error. | 2016-01-13 21:21:55
GainCapital FAST Data socket (67) | Shutdown and closed. | 2016-01-13 21:21:55
GainCapital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-01-13 21:21:55
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:21:55
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:24:55
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:24:55
GainCapital FIX Trading socket (70) | Connected. | 2016-01-13 21:24:55
GainCapital FIX Trading socket (70) | Starting TLS 1.2 connection. | 2016-01-13 21:24:55
GainCapital FIX Trading socket (70) | SSL connection established. | 2016-01-13 21:24:56
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:24:56
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:24:56
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:24:56
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:24:56
GainCapital FAST Data socket (71) | Connected. | 2016-01-13 21:24:56
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:24:56
GainCapital FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:24:56
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:24:56
GainCapital FIX Trading socket (70) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:24:56
GainCapital FIX Trading socket (70) | SSL has been shut down. | 2016-01-13 21:24:56
GainCapital FIX Trading socket (70) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:24:56
GainCapital FIX Trading socket (70) | Shutdown and closed. | 2016-01-13 21:24:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:24:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:24:56
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:24:56
GainCapital FAST Data: Sending a Logout message. | 2016-01-13 21:24:56
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:24:56
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:24:56
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:24:57
GainCapital FAST Data socket (71) | Closed. No error. | 2016-01-13 21:24:57
GainCapital FAST Data socket (71) | Shutdown and closed. | 2016-01-13 21:24:57
GainCapital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-01-13 21:24:57
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:24:57
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:27:56
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:27:56
GainCapital FIX Trading socket (73) | Connected. | 2016-01-13 21:27:57
GainCapital FIX Trading socket (73) | Starting TLS 1.2 connection. | 2016-01-13 21:27:57
GainCapital FIX Trading socket (73) | SSL connection established. | 2016-01-13 21:27:59
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:27:59
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:27:59
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:27:59
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:27:59
GainCapital FAST Data socket (74) | Connected. | 2016-01-13 21:27:59
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:27:59
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:28:00
GainCapital FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:28:00
GainCapital FAST Data: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:28:00
GainCapital FAST Data socket (74) | Shutdown and closed. | 2016-01-13 21:28:00
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:28:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:28:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:28:00
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:28:00
GainCapital FIX Trading: DisconnectFIX called. | 2016-01-13 21:28:00
GainCapital FIX Trading: Sending a Logout message. | 2016-01-13 21:28:00
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:28:00
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:28:00
GainCapital FIX Trading: Received a Logout message. | 2016-01-13 21:28:00
GainCapital FIX Trading socket (73) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:28:00
GainCapital FIX Trading socket (73) | SSL has been shut down. | 2016-01-13 21:28:00
GainCapital FIX Trading socket (73) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:28:00
GainCapital FIX Trading socket (73) | Shutdown and closed. | 2016-01-13 21:28:00
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:28:00
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:31:00
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:31:00
GainCapital FIX Trading socket (77) | Connected. | 2016-01-13 21:31:00
GainCapital FIX Trading socket (77) | Starting TLS 1.2 connection. | 2016-01-13 21:31:00
GainCapital FIX Trading socket (77) | SSL connection established. | 2016-01-13 21:31:00
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:31:00
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:31:01
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:31:01
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:31:01
GainCapital FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:31:01
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:31:01
GainCapital FIX Trading socket (77) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:31:01
GainCapital FIX Trading socket (77) | SSL has been shut down. | 2016-01-13 21:31:01
GainCapital FIX Trading socket (77) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:31:01
GainCapital FIX Trading socket (77) | Shutdown and closed. | 2016-01-13 21:31:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:31:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:31:01
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:31:01
GainCapital FAST Data socket (78) | Shutdown and closed. | 2016-01-13 21:31:01
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:31:01
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:31:01
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:31:01
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:31:01
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:34:01
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:34:01
GainCapital FIX Trading socket (80) | Connected. | 2016-01-13 21:34:01
GainCapital FIX Trading socket (80) | Starting TLS 1.2 connection. | 2016-01-13 21:34:01
GainCapital FIX Trading socket (80) | SSL connection established. | 2016-01-13 21:34:02
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:34:02
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:34:02
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:34:02
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:34:02
GainCapital FAST Data socket (81) | Connected. | 2016-01-13 21:34:02
GainCapital FAST Data: Sending the Hello message. | 2016-01-13 21:34:02
GainCapital FAST Data: Sending the Logon message. | 2016-01-13 21:34:03
GainCapital FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:34:03
GainCapital FAST Data: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:34:03
GainCapital FAST Data socket (81) | Shutdown and closed. | 2016-01-13 21:34:03
GainCapital FAST Data: Logged out and disconnected. | 2016-01-13 21:34:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:34:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:34:03
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:34:03
GainCapital FIX Trading: DisconnectFIX called. | 2016-01-13 21:34:03
GainCapital FIX Trading: Sending a Logout message. | 2016-01-13 21:34:03
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:34:03
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:34:03
GainCapital FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2016-01-13 21:34:03
GainCapital FIX Trading socket (80) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:34:03
GainCapital FIX Trading socket (80) | SSL has been shut down. | 2016-01-13 21:34:03
GainCapital FIX Trading socket (80) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:34:03
GainCapital FIX Trading socket (80) | Shutdown and closed. | 2016-01-13 21:34:03
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:34:03
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-01-13 21:37:03
GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:37:03
GainCapital FIX Trading socket (84) | Connected. | 2016-01-13 21:37:03
GainCapital FIX Trading socket (84) | Starting TLS 1.2 connection. | 2016-01-13 21:37:03
GainCapital FIX Trading socket (84) | SSL connection established. | 2016-01-13 21:37:03
GainCapital FIX Trading: Sending the Logon message. | 2016-01-13 21:37:04
GainCapital FIX Trading | Connected to trading server. | 2016-01-13 21:37:04
GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-01-13 21:37:04
GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2016-01-13 21:37:04
GainCapital FIX Trading: Received a Logout message. | 2016-01-13 21:37:04
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-13 21:37:04
GainCapital FIX Trading socket (84) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-13 21:37:04
GainCapital FIX Trading socket (84) | SSL has been shut down. | 2016-01-13 21:37:04
GainCapital FIX Trading socket (84) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 21:37:04
GainCapital FIX Trading socket (84) | Shutdown and closed. | 2016-01-13 21:37:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 21:37:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 21:37:04
GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-13 21:37:04
GainCapital FAST Data socket (85) | Shutdown and closed. | 2016-01-13 21:37:04
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-01-13 21:37:04
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-01-13 21:37:04
GAIN Capital/OEC | Disconnected. | 2016-01-13 21:37:04
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 21:37:04
Date Time Of Last Edit: 2016-01-13 22:33:43
[2016-01-14 02:17:47]
These are the relevant messages:
Follow the instructions here:
http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem
