Date/Time: Fri, 02 Oct 2026 12:49:33 +0000
SC won't log on toquote server
View Count: 1023
| [2016-01-13 19:42:47] |
| southworth123 - Posts: 9 |
I'm using transact futures for my quotes. Using the transact quote program directly, I can log into the quotes. When I start SC, it is unable to log into the quotes. It gives me the message that target refused the connection. In suding xp and sc version 1354. My service is paid up to Jan 21, 2016. Here is the log. Software version: 1354 | 2016-01-13 13:04:29 Uses New Spreadsheets | 2016-01-13 13:04:29 Usage end date: 2016-01-21 | 2016-01-13 13:04:29 Enabled for: Advanced Features. | 2016-01-13 13:04:29 Enabled for: Sierra Chart Historical Data Service. | 2016-01-13 13:04:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-13 13:04:29 Current selected Data/Trading service: TransAct Trading | 2016-01-13 13:04:29 Chart Update Interval: 500 | 2016-01-13 13:04:29 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-01-13 13:04:29 2016-01-13 11:04:29 Local computer time | 2016-01-13 13:04:29 2016-01-13 19:04:29 Local computer time in UTC | 2016-01-13 13:04:29 2016-01-13 13:04:29 Local computer time in SC Time Zone | 2016-01-13 13:04:29 2016-01-13 19:04:28 Server time in UTC | 2016-01-13 13:04:29 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-01-13 13:04:29 Program path: C:\SierraChart\ | 2016-01-13 13:04:29 Data Files path: C:\SierraChart\Data\ | 2016-01-13 13:04:29 OS Version Number: 5.1 | 2016-01-13 13:04:29 Locale Information: C | 2016-01-13 13:04:29 Checking for new symbol settings for ta | 2016-01-13 13:04:29 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-13 13:04:29 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-01-13 13:04:29 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-01-13 13:04:29 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-01-13 13:04:29 Requesting symbol settings for ta. Overwrite = on. | 2016-01-13 13:04:30 Symbol settings received. | 2016-01-13 13:04:30 Processed received symbol settings | 2016-01-13 13:04:31 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:34 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-01-13 13:04:35 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-01-13 13:04:35 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-01-13 13:04:35 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:04:36 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:04:37 Socket (4) | Shutdown and closed. | 2016-01-13 13:04:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:04:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:04:37 TransAct Trading | Disconnected. | 2016-01-13 13:04:37 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:04:37 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:39 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:04:41 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:04:42 Socket (5) | Shutdown and closed. | 2016-01-13 13:04:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:04:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:04:42 TransAct Trading | Disconnected. | 2016-01-13 13:04:42 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:04:42 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:44 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:04:46 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:04:47 Socket (6) | Shutdown and closed. | 2016-01-13 13:04:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:04:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:04:47 TransAct Trading | Disconnected. | 2016-01-13 13:04:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:04:47 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:04:51 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:04:52 Socket (7) | Shutdown and closed. | 2016-01-13 13:04:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:04:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:04:52 TransAct Trading | Disconnected. | 2016-01-13 13:04:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:04:52 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:54 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:04:56 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:04:57 Socket (8) | Shutdown and closed. | 2016-01-13 13:04:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:04:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:04:57 TransAct Trading | Disconnected. | 2016-01-13 13:04:57 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:04:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:04:59 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:01 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:05:02 Socket (9) | Shutdown and closed. | 2016-01-13 13:05:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:05:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:05:02 TransAct Trading | Disconnected. | 2016-01-13 13:05:02 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:05:02 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:05:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:06 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:05:07 Socket (10) | Shutdown and closed. | 2016-01-13 13:05:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:05:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:05:07 TransAct Trading | Disconnected. | 2016-01-13 13:05:07 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:05:07 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:05:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:11 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:05:12 Socket (11) | Shutdown and closed. | 2016-01-13 13:05:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:05:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:05:12 TransAct Trading | Disconnected. | 2016-01-13 13:05:12 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:05:12 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:05:14 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:16 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:05:17 Socket (12) | Shutdown and closed. | 2016-01-13 13:05:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:05:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:05:17 TransAct Trading | Disconnected. | 2016-01-13 13:05:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:05:17 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:05:19 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:21 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-13 13:05:22 Socket (13) | Shutdown and closed. | 2016-01-13 13:05:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-13 13:05:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-13 13:05:22 TransAct Trading | Disconnected. | 2016-01-13 13:05:22 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-13 13:05:22 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-01-13 13:05:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-01-13 13:05:26 |
| [2016-01-14 04:16:13] |
Refer to the documentation here about this: http://www.sierrachart.com/index.php?page=doc/TransAct.php#BridgeConnectionError There are several possible causes of this problem. To be sure to go through all of the items listed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
