Date/Time: Sat, 28 Dec 2024 07:27:42 +0000
'Difference' Study - problem with accuracy of candles
View Count: 1226
[2016-01-13 16:22:42]
User382041 - Posts: 8
I am charting an oil spread using the 'Difference' study. The spread is (Outright) - (5 x Dec15/Dec16 spread). Under the 'Subgraphs' tab within the 'Difference' study, I have changed the graph draw type from line to candlestick. The accuracy of the wicks of these candles is incorrect. For example, I can sit and watch the 15 minute graph and watch the price fall and then retrace, yet no wick will be formed so that if I had not been watching the price action, I would be oblivious to this price movement. The same problem occurs with all timeframes.
Do you have any solutions for this please?
Thanks.
[2016-01-13 18:18:38]
You need to follow the instructions here to create a high accuracy spread chart:
How to Create High Accuracy Spread or Ratio Charts
[2016-01-13 18:35:20]
Thank you for pointing this out, and sorry for not having checked it before posting.
