Date/Time: Sat, 28 Dec 2024 07:50:58 +0000
Display of number bars
View Count: 763
[2016-01-13 14:07:22]
User121044 - Posts: 2
Hello, I have a question to display numbers bars. Specifically, the setting Column background type. By selecting Volume profile, horizontal dimensions of the volume in the candle (numbers bars), or more precisely their length, are displayed based on the logic in the choice of the maximum amount of candles (number bar) and construction of the remaining volume (length of the horizontal volume) is proportional to the maximum in the candlestick.
It is a way to display based on the logic of selecting the maximum volume on the entire chart (the visible part) and further mapping the size of the horizontal volumes (their length) in a candle (numbers bar) proportional to the maximum volume on the entire schedule.
Thank you in advance for your reply.
Date Time Of Last Edit: 2016-01-13 14:08:12
[2016-01-13 18:48:05]
We know what you want and this is not supported. This will come at a future time. We do not know when.
