Date/Time: Wed, 30 Sep 2026 09:55:28 +0000
Forex pairs
View Count: 1016
| [2016-01-13 08:07:47] |
| User934677 - Posts: 5 |
I have a new account with AMP and am using CQG data feed and the Sierra chart platform. On the platform, I notice that I can choose a forex pair under "Symbol." But once the chart is up, the feed is not live and nothing is moving. Do I have access to the Forex pairs? If not, is there a way that I can get access to them through Sierra chart? Thank you, Kevin Baker |
| [2016-01-13 10:42:47] |
The Forex symbols are only available with a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-13 17:53:26] |
Can you tell me if I were to use the TTNet data feed instead of CQG through AMP, would TTNet give me access to the Forex pairs or any advantage? By the way, can you tell me the cost of a direct account with Sierra? And where can I find a layout of all of the costs involved with a direct account (commissions, all transactions fees involved, monthly fees, etc.)? Thank you, Kevin |
| [2016-01-13 18:33:06] |
Pricing can be found on this page here: Description of Service Packages and Pricing: Packages TT Net does not provide Forex pairs. Only futures data. Commissions and transaction fees are not affected by a direct Sierra Chart account. Those are charged by your trading/broker service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
