Date/Time: Thu, 28 Nov 2024 20:37:13 +0000
[Locked] - How to see every change in the Bid/Ask Average
View Count: 1192
[2016-01-13 06:26:02] |
User760942 - Posts: 120 |
Hi SC, Is it possible to make a chart that creates a new bar everytime the Bid/Ask Average changes even when a Trade did not happen? I tried doing this via making a chart with the -BAAVG suffix, but could not figure out which "Bar Period Type" to use. Each "Bar Period Type" seemed to show the Bid/Ask Average only when a Trade happened. |
[2016-01-13 08:44:00] |
The -BAAVG data recording mode is definitely the correct one to use. All Bar Period Types are supported when using this. This setting has no relevancy when it comes to what data is recorded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-13 08:44:19
[2016-01-13 19:39:13] |
Great. Is it possible to make a chart that creates a new bar everytime the Bid/Ask Average changes even when a Trade did not happen?
Which "Bar Period Type" would I use to to make the chart mentioned in the quote above? |
[2016-01-13 20:05:35] |
You need to use: Number of Trades Per Bar = 1
[2016-01-13 20:31:04] |
I tried that. It only showed what the bid/ask average was at the time of a trade. I need it to show what the bid/ask average was in between trades as well. |
[2016-01-13 20:44:13] |
To do this properly, it is not yet supported. We know what you want and we have not yet developed that. Please allow us about another three weeks.
[2023-04-09 10:47:52] |
User799255 - Posts: 24 |
Hi, Bumping this up to see if there was any follow up please? Thanks |
[2023-04-09 11:11:20] |
Sierra_Chart Engineering - Posts: 17206 |
This thread is old. You cannot make reference to an existing thread. You must restate your question thoroughly and clearly. And start a new thread. This is now locked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
