Date/Time: Sun, 20 Sep 2026 08:00:52 +0000
Show trade filled on chart for analysis?
View Count: 916
| [2016-01-12 22:50:09] |
| JingIt - Posts: 44 |
I'm quite a visual people so I would like to analysis my trade journal through the chart so I can see how I position myself compare to the price action etc. Is there any way to show the order filled dot on the chart base on the trade activity log? Thank you |
| [2016-01-13 02:43:47] |
You are able to display the order fills directly on the chart if that is what you are asking about. This is thoroughly documented here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
