Date/Time: Wed, 16 Sep 2026 09:15:55 +0000
Data feed for EUREX with gateway in London or Frankfurt
View Count: 1578
| [2016-01-12 19:52:07] |
| User389415 - Posts: 3 |
Hello. Tell me please do you have FDAX data feed that takes exchange data in Frankfurt and route it directly to gateway in Frankfurt or in London? Frankfurt is better...)) Date Time Of Last Edit: 2016-01-12 19:52:54
| [2016-01-13 02:40:57] |
The Sierra Chart Exchange Data Feed does not provide this. We recommend checking with CQG or Rithmic: http://www.sierrachart.com/index.php?page=doc/Data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-13 09:51:22] |
Thanks. I already used Rithmic and CQG. Rithmic EUREX data feed in Europe have too mach delay due it routes via Chicago. CQG routes via London but it have too many throttles. what you can say about TeleTrader and IQFeed? do you know how it routes? |
| [2016-01-13 10:01:04] |
Contact TeleTrader. There is little doubt IQ Feed would originate from the US like our data feed does. The Sierra Chart Exchange Data Feed has servers in Chicago. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-14 13:32:37] |
Do you have CQG gateway in Europe?
| [2016-01-14 17:58:50] |
If CQG has a Web API server in Europe, then Sierra Chart can be set to use that. We do not know whether CQG has this. But we will ask them.
| [2016-01-15 00:33:54] |
Interestingly CQG does not have a server in Europe. This is what they said though: We are currently discussing an installation in London.
