Date/Time: Tue, 26 Nov 2024 00:18:38 +0000
SC Forex data Failed for Dow 30
View Count: 848
[2016-01-12 15:24:29] |
Matt654 - Posts: 73 |
Hi Support SC Forex data failed for Dow 30 @ 14:50 hrs approx. and is still 30 mins later, any suggestions. Will the data feed be starting again shortly or should I write the day off. Matt PS looks like its just started again with a huge red bar. |
[2016-01-12 16:08:57] |
Sierra Chart - Max - Posts: 5731 |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support |
[2016-01-12 17:25:27] |
We will be patching the missing data at the end of the day.
[2024-01-18 15:36:36] |
US30 CFD data stopped altogether about 20 mins ago.
[2024-01-18 16:04:17] |
User225841 - Posts: 4 |
SC-Data services has been going out lately. I lost connection on all my charts more than once today. Is this service reliable anymore? Sending you my message log from today. Thanks for any and all help.
[2024-01-18 16:28:20] |
Hi User225841 I only trade the US30, but I have been using SC data for about 20 yrs and probably had brief data problems about once or twice a year. I only use free SC data (CFDs data) I don't know anything about the other data sources. Best Regards Matt
[2024-01-18 17:01:37] |
John - SC Support - Posts: 36286 |
FXCM had some issues earlier today, but we see the data is flowing right now.
[2024-01-19 01:28:56] |
Sierra_Chart Engineering - Posts: 17178 |
The data you are referring to is from FXCM and no FXCM is not entirely reliable. We recommend using the Delayed Exchange Data Feed instead and the NASDAQ Global indexes which are totally reliable. Refer to: Delayed Exchange Data Feed https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#NASDAQGlobalIndexDataFeed To download any missing data you might have related to the FXCM interruption, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-19 01:29:39
