Date/Time: Sat, 28 Dec 2024 07:31:27 +0000
Numbers Bars Calculated Incorrectly
View Count: 715
[2016-01-12 03:41:57] |
User40877 - Posts: 16 |
Hi, there's a problem with the "Numbers Bars Calculated" study. The current bar is incorrectly updating data. Attached is a video I made demonstrating the problem. My current version is 1352.
Private File |
[2016-01-12 04:13:38] |
We are checking this now.
[2016-01-12 04:18:51] |
We have identified the problem and we will have a new release out in about 10 minutes.
[2016-01-12 08:34:34] |
Letting you know, we did do the release which corrects this problem. Update Sierra Chart with Help >> Download Prerelease. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-12 13:25:27] |
The problem still persists in version 1353 which I show as the latest version.
[2016-01-12 17:39:28] |
This was solved. Make sure you are on the latest revision because it was not until the second revision of 1353. Update with Help >> Download Prerelease. We will test this again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-12 18:09:19] |
I loaded the prerelease 1353 and the problem is resolved. Thankyou.
