Date/Time: Tue, 29 Sep 2026 12:53:33 +0000
Autotrading formula question
View Count: 1101
| [2016-01-11 15:27:56] |
| User517837 - Posts: 2 |
Hello- I am using a crossover formula (crossfromabove, crossfrombelow) for trade entry and exit. When I enter these formulas in the Spreadsheet for Trading spreadsheet, a FALSE value is returned for columns K,L,M,N. These formulas function normally in the Color Bar Based on Alert Condition. Example: =crossfromabove(id12.sg1@3, id14.sg1@3) I have tried omitting the "@3" function, to no avail. By creating a formula with "greater than (>), less than (<), autotrading functions...I would prefer using the crossfromabove/below function though. Thanks for your help. |
| [2016-01-12 00:08:15] |
We are looking into this now: =crossfromabove(id12.sg1@3, id14.sg1@3)
| [2016-01-12 00:39:22] |
The problem is you did not specify a range of 2 cells for each parameter. There is only a single cell for each parameter as you have it now. Refer to the "Spreadsheet Functions" documentation for an example. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
