Date/Time: Thu, 10 Sep 2026 06:55:32 +0000
Study Color Bar Based on do not calculate permanently
View Count: 980
| [2016-01-11 11:36:01] |
| nicktrader - Posts: 811 |
I am using (I try) the Study "Color Bar ... Alert..." with an alert Condition as you can see in the attached file. The study do not calculate permanently. It works only after a "Button click" Apply. What is the problem? |
| [2016-01-11 17:58:27] |
This is not completely clear for us. From our perspective it is hard to perceive exactly what is happening and why. There definitely is no problem with the study itself. That would be very unlikely. Provide a Chartbook containing a single chart with this study by following the instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-11 21:07:24] |
Please find attached the CB
Private File |
| [2016-01-11 23:14:48] |
You need to read this section here to understand the problem: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#UsingPositiveBarOffsetsConsequences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
