Date/Time: Sat, 28 Dec 2024 05:08:32 +0000
Intraday Chart Weekly
View Count: 668
[2016-01-11 06:58:31] |
User297539 - Posts: 55 |
Hello SC. I would like to upload Intraday Chart with Weekly Candlestick Bar. Put setting to 7 Days, but each Weeks Candle will now begin from Friday. How can I change that until Monday the Candels beguines?
11-01-2016 07-36-44.jpg / V - Attached On 2016-01-11 06:55:50 UTC - Size: 274.12 KB - 265 views Attachment Deleted. 11-01-2016 07-53-35.jpg / V - Attached On 2016-01-11 06:57:10 UTC - Size: 168.68 KB - 264 views |
[2016-01-11 10:29:58] |
The solution to this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DaysMinutesSeconds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
