Date/Time: Tue, 22 Sep 2026 19:05:30 +0000
acsil & spreadsheets suggestion
View Count: 916
[2016-01-11 02:08:02]
enemyspy - Posts: 307
I wonder if it would be easy to implement acsil/ spreadsheet functionality that allows you to display the result of a persistent variable in a single non subgraph cell on a spreadsheet. For instance I would find this useful for creating a statistics panel, instead of using the sc.Usetool to print/update each stat in a graph region.
Date Time Of Last Edit: 2016-01-11 02:08:28
