Date/Time: Fri, 11 Sep 2026 03:02:59 +0000
weekly profile cpu killer ?
View Count: 1269
[2016-01-11 01:08:19]
User20450 - Posts: 330
hey was wondering why when i load a weekly tpo/vp chart my cpu usage goes to 15-25% and even worse if i zoom out to see more profiles ,
very heavy load on this ,
ios there any thing i can do to reduce load ?
thanks
[2016-01-11 01:28:17]
Refer to help topic 30.34:
https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.34
[2016-01-11 01:38:45]
ok yes i see that and have tried that but kinda defeats the purpose of having precision , take about a 25 block to speed it up to a daily tpo ., i guess let me know if there is any fix or update in this coming , as not issue in other platforms , thanks
[2016-01-11 01:53:08]
There is nothing for us to fix. The issue has to do with what is being displayed. You will need to use another program because we do not see how we can make this better.
However, before you switch to another program we recommend that you update your computer hardware to make it faster.
Date Time Of Last Edit: 2016-01-11 01:54:29
[2016-01-11 01:57:04]
Although if you post an image of the chart, we may be able to see something such as relating to the color settings. We can then give you a recommendation as what you could change that can help.
Date Time Of Last Edit: 2016-01-11 01:58:00
