Date/Time: Thu, 16 Jan 2025 01:16:30 +0000
How to read Trade Activity Log file tradingactivitylog.dat ?
View Count: 1879
[2016-01-10 05:05:48] |
User368248 - Posts: 46 |
Hello. I want to open/read the file tradingactivitylog.dat for check/track the status of each order submitted to FIX provider and integrate into acsil code for reliable way to know when a order was accepted by provider. Can you provide me the format to read externally such file? Thanks. |
[2016-01-10 07:59:36] |
This is not within the scope of our support. We have answered another question of yours that may resolve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-10 08:19:23] |
Also, we can provide another ACSIL function which lets you access any record type in the Trade Activity Log with more parameters to control specifically what you need to get.
[2016-01-11 13:05:59] |
Thanks, please provide me such acsil code. Thanks. |
[2016-01-12 04:34:34] |
We will put this on our task list but we do not know how soon it could be done. Allow about 30 to 60 days.
[2017-10-02 12:41:15] |
User215677 - Posts: 3 |
Hi, is the feature/function already done? Can I access Trade Activity Log records via any ACSIL function? |
[2017-10-02 17:21:00] |
No, this is still not supported. However, you can access the Trades. Refer to: Automated Trading From an Advanced Custom Study: sc.GetTradeListEntry() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-02 17:21:11
