Date/Time: Sat, 28 Dec 2024 04:24:31 +0000
[User Discussion] - Extended rectangle, extended lines
View Count: 1063
[2016-01-09 20:58:05] |
JosefPetran - Posts: 7 |
Dear Support Board, I would like to ask one technical question. I operate with two types of graphs 30 min + 2 min. Into the 30 min I draw some extended rectangle + lines and the question is, if it si possible, when I draw this into the 30 min graph, can it be displayed as well in to the 2 min graph together at the same time of drawing? Thank you very much for your answer. BR. Josef |
[2016-01-10 01:14:25] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
