Date/Time: Sat, 28 Dec 2024 01:09:51 +0000
GER 30
View Count: 870
[2016-01-08 09:16:38] |
ripsdips - Posts: 143 |
Is there a problem with GER 30 feed?
[2016-01-08 09:45:09] |
There is no current problem with GER30. Not sure this is the problem, but update to the current version of Sierra Chart: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate And if you still have a problem, refer to this help topic: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
