Date/Time: Sat, 28 Dec 2024 01:28:36 +0000
ChartDOM current bid ask volume take off?
View Count: 822
[2016-01-08 08:58:51] |
User567294 - Posts: 47 |
I just upgrade to version 1350, but the ChartDOM's current bid ask volume gone, how to get it on? thanks Rex |
[2016-01-08 09:15:41] |
We did some work on these market data columns. We are going to check on this now. What symbol is this happening for? Just give us one of the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-08 09:27:33] |
CL and ES. Thanks Rex |
[2016-01-08 10:28:36] |
This is now solved. You need to update to version 1351. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
