Date/Time: Mon, 27 Jan 2025 04:36:18 +0000
How to change price text size to be larger
View Count: 1227
[2016-01-08 07:58:51] |
idcisosf - Posts: 34 |
Hi, I'd like to know how to change price text size to be larger on a chart? And how to change background color on a chart? And how to make order fill point to be bigger and line to be thinker on a chart? Thanks, |
[2016-01-08 18:43:51] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html To make the Order Fill markers larger, refer to: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-28 12:51:16] |
Yeager - Posts: 128 |
Is it possible to make the fills marker triangles bigger? Have not found that setting in the /chart trade settings area.
[2019-02-28 17:18:47] |
John - SC Support - Posts: 37478 |
Refer to this setting: Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
