Date/Time: Thu, 31 Oct 2024 10:12:47 +0000
6jh6 chart problem (oec)
View Count: 698
[2016-01-07 18:44:44] |
User411334 - Posts: 38 |
Please take a look. An issue similar to this one was with soybean oil chart.
[2016-01-07 19:06:24] |
We made some corrections to the Symbol Settings for these symbols. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After this is done re-download the data in the chart with Edit >> Delete All Data and Download. However, it also looks as though the scaling is not set right in the chart you are looking at. So go through the instructions here to use a default scale: https://www.sierrachart.com/index.php?page=doc/helpdetails46.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
