Date/Time: Thu, 31 Oct 2024 10:12:39 +0000
Chart window deleted in error.
View Count: 910
[2016-01-07 16:22:34] |
User41512 - Posts: 58 |
Hi. Is there a way to recover a chart window (an individual chart) which has been deleted in error..I have not previously backed it up. Thks
[2016-01-07 18:04:39] |
Possibly. If you did not save the Chartbook you can close the Chartbook without saving and reopen it to restore the chart: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#RestoringChart There are also backup Chartbooks available: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-07 18:05:27
