Date/Time: Sun, 20 Sep 2026 18:15:31 +0000
Link 2 copies of Sierra Chart with the same quote board screen?
View Count: 1131
| [2016-01-06 21:19:04] |
| Stephan908 - Posts: 46 |
I have 2 copies of Sierra Chart. One for data/charting and the other for trading using the Sierra DOM. Is there a way to link the 2 copies together so if I click on a symbol on the Quoteboard, it will automatically switch the chart and the DOM to the same symbol? Thanks.
| [2016-01-06 21:26:10] |
No.
| [2016-01-07 01:50:26] |
Ok thanks. Last question.. (sorry I'm a new user) I don't see a section for feature requests.. any plan to add the option to display the symbol/ticker in the background so it will be easier to tell quickly which chart you're looking at if you have a lot of them open? Thanks again. |
| [2016-01-07 02:02:49] |
At this time we are not accepting new feature requests.
