Date/Time: Fri, 27 Dec 2024 15:11:23 +0000
total number of bars
View Count: 850
[2016-01-06 21:17:41] |
User780665 - Posts: 3 |
Hey Guys, I want to connect with your Platform using TeleTrader. Therefore, I have to translate my indicators =( Can you tell me how I can get the total number of bars in the chart? In TeleTrader this was simply possible with the command "CurrendBar" (Returns the index number of the current bar). Do you have a code for me? Many Thanks! greetings from Germany =) Roman |
[2016-01-06 21:38:00] |
This is sc.ArraySize when using ACSIL: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-06 23:27:20] |
I did it with "sc.Index" and it works now. But thanks for the quick feedback!
