Date/Time: Fri, 27 Dec 2024 14:58:51 +0000
Bid & Ask Depth Bars - on historical data?
View Count: 1040
[2016-01-06 20:13:24] |
User61576 - Posts: 445 |
i assume Bid & Ask Depth Bars can not be done on historical tick data i have in my files, but, if i have the data "recorded" live, is it being stored as well for a future use?
[2016-01-06 21:04:09] |
The data for that study is not stored.
