Date/Time: Fri, 27 Dec 2024 15:01:09 +0000
EUREX Data Feed
View Count: 783
[2016-01-06 07:23:30]
User39772 - Posts: 311
Hello, my Eurex Datafeed seems to not work this Morning.
When I ConnecT/disconnect Datafeed I get a backfill, but no continuous data update, no DOM etc. available.
[2016-01-06 07:25:46]
We are checking this now.
[2016-01-06 07:43:08]
Are you still noticing a problem?
The EUREX data from the Sierra Chart Exchange Data Feed is working properly.
[2016-01-06 08:05:36]
Yes, I get the message "Symbol is unknown" for ESTX50-201603-DTB with no DOM and no realtime ticks. Restarted sc and TWS several times. The NQ at GLOBEX e.g. works as expected, so only Problem with EUREX.
[2016-01-06 08:32:25]
This is now solved for your account. Restart Sierra Chart.
[2016-01-06 08:49:57]
Hello, restarted and updated SC to 1346, unfortunately same problem persists ...
[2016-01-06 09:03:13]
This was our mistake. We did not confirm the activation. This is now done.
Restart Sierra Chart again. We apologize for this.
