Date/Time: Fri, 27 Dec 2024 15:35:25 +0000
eurex
View Count: 914
[2016-01-06 07:21:30] |
User60358 - Posts: 47 |
My add service eurex dosnt work. Ive got credit .. can you check?
[2016-01-06 07:25:32] |
We are checking this now.
[2016-01-06 07:32:31] |
EUREX is not active on your account. Do you want us to activate that exchange for you?
[2016-01-06 07:52:41] |
Yes
[2016-01-06 07:53:46] |
But it was active, I payed and I enabled it the 3ist of current month
[2016-01-06 08:21:04] |
<Please, can you check? I ' sure I payed ( I've receipt) and enable eurex, so I dont want to pay 2 times
[2016-01-06 08:27:22] |
We have activated the EUREX exchange on your account. Restart Sierra Chart. We apologize for the delay.
[2016-01-06 08:34:11] |
thank you
