Date/Time: Fri, 27 Dec 2024 15:17:34 +0000
Merged non-back adjusted charts
View Count: 1128
[2016-01-06 04:12:45] |
user40663 - Posts: 54 |
currently using intraday charts to display 1440m candles (1 day) with IB for data. is it possible to have charts show non back adjusted charts this way? |
[2016-01-06 10:45:36] |
Yes you can do this. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
