Date/Time: Fri, 27 Dec 2024 15:24:56 +0000
Tagged Charts
View Count: 968
[2016-01-05 20:59:43]
User99735 - Posts: 234
I am opening a new chart #4 from an existing chart#1.
Once the download of historical data for chart #4 is complete, full recalculation is done in Chart #1.
Can the full recalculation be avoided in Chart #1, or the only option is to use code
if (sc.IsFullRecalculation ||
    sc.ServerConnectionState != SCS_CONNECTED)
    return;
Excerpts from log file enclosed.
Regards
Vivek
"Chart #4 has tagged chart #1 for full recalculation. Chartbook: Chartbook-AAPL.cht | 2016-01-05 12:41:15
AAPL [M] 1 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook-AAPL.cht | 2016-01-05 12:41:15"
[2016-01-05 21:39:09]
There is no way to avoid the full recalculation other than for the study itself in the way that you have shown above.
[2016-01-05 22:03:08]
Thanks.
Is sc.IsFullRecalculation set to true, when a study is attached to chart for first time also?
If yes, are there any other flags available similar to sc.SetDefaults, to do initializations?
Regards
Vivek
[2016-01-06 05:15:47]
Yes.
When sc.Index equals 0, you can do initializations relating to a full recalculation.
