Date/Time: Fri, 27 Dec 2024 15:02:43 +0000
Classical tick chart not populating properly
View Count: 758
[2016-01-05 20:30:01]
User771540 - Posts: 1
I would like to make a classical tick chart.
However, as soon as I put in the value ‘number of trades per bar’ and makes it ‘1’, the chart appears like in the screenshot attached.
Can you tell me what the issue would be? I want to see a moving tick chart where a new bar is drawn, but this chart becomes completely flat with horizontal bars.
Please assist.
Thank you!
image!!!.jpg / V - Attached On 2016-01-05 20:28:15 UTC - Size: 194.62 KB - 279 views
image!!!!!!!!!!!!!!!!!!!!!!!.jpg / V - Attached On 2016-01-05 20:29:23 UTC - Size: 144.78 KB - 293 views
image2!!!!!!!!!!!!!!!!!!!!!!.jpg / V - Attached On 2016-01-05 20:29:44 UTC - Size: 145.34 KB - 350 views
[2016-01-05 20:36:15]
It is hard for us to tell exactly what you are completely seeing in the chart from those screenshots.
Follow the instructions here to upload a chart image:
You need to use Edit >> Screen Images >> Upload Chart.
Date Time Of Last Edit: 2016-01-06 21:24:25
[2016-01-06 21:25:24]
Refer to this help topic:
http://www.sierrachart.com/index.php?page=doc/helpdetails46.html
