Date/Time: Fri, 27 Dec 2024 14:58:23 +0000
Writing Functions
View Count: 689
[2016-01-05 19:27:03] |
maxpi - Posts: 181 |
I'm trying to pass sc.Basedata into a function I'm writing/calling. Can you point me to some example code of same?
[2016-01-05 21:37:10] |
Refer to the function scsf_PassingSCStructureExample in the/ACS_Source/Studies2.cpp file.
