Date/Time: Mon, 28 Oct 2024 08:57:48 +0000
Trial for Canadian Stocks (TSX)
View Count: 1418
[2016-01-05 16:57:53] |
User636069 - Posts: 26 |
Hello, How can I get 1-2 weeks trial of Sierra chart with real data TSX data? Does your data is real without any delay? I'm going to open an account with IB and get Sierra as platform if it meets my requirement. Thanks |
[2016-01-05 21:15:27] |
A trial is not available for the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php If that is what you are referring to. The data is real-time without any delay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-14 18:22:01] |
We tested the TSX exchange with the Sierra Chart Exchange Data Feed and we see no problem with this. So we know that it will work for you. Here is a chart of one of the stocks on the TSX: http://www.sierrachart.com/image.php?l=1452795647714.png While we do not provide a real-time data trial, you can access the historical data through the Sierra Chart Historical Data Service and test that: Sierra Chart Historical Data Service The supported symbols can be found here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=8#TSX https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=9#TSXV Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-14 18:23:32
[2016-01-26 01:51:00] |
Thank you so much. One more question. I am wondering if I will be able to see the 'Cumulative Delta bars- up/down tick volume' indicator by linking the IB level 1 data for TSX (Toronto stock exchange) to the Sierrachart platform? |
[2016-01-26 01:59:33] |
This is not going to be accurate at all and we will not provide help with this. You have to use a quality reliable data feed like the Sierra Chart Exchange Data Feed when using Cumulative Delta Bars. Using Interactive Brokers data will be terribly unreliable with that study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
