Date/Time: Wed, 09 Sep 2026 22:10:25 +0000
Volume by Price
View Count: 1872
[2016-01-05 14:12:59]
Kefir - Posts: 34
I have created VbP study on 30min time frame of SPY. When I duplicated that chart and set the time frame to daily I experienced that Point of Control for the whole day is charted on a totally different level than showing on 30min time frame. Volume of POC is also much bigger.
Is there some explanation?
Can I overlay POC from 30min bar on the daily chart?
Kind regards
ra
[2016-01-06 06:14:40]
You will get completely different results when using the Volume by Price study on a Intraday chart and a Historical Daily chart.
You need to use Intraday data only:
Chart Session Times: Creating Daily Bars with Custom Session Times
Yes you can do the Point of Control overlay. This can be done with the Study/Price Overlay study. Refer to the documentation for this study.
[2016-01-06 14:20:17]
Kefir - Posts: 34
can you please explain why I get different Point of Control for the day session when using 30min timeframe and daily timeframe? There is for the whole day only one price level on which was the most volume traded.
Can you please explain how to overlay only Point of Control from the 30min chart? The furthest I got is to select in the Study/Price Overlay the 30min chart and the study ID (but nothing is displayed on the daily chart anyway) but I don't know where to select sg.2 in the Study/Price Overlay study.
Kind regards
ra
[2016-01-07 10:44:32]
This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#HowVolumeAtPriceCalculatedForDailyCharts
For the overlay it is best to use the Volume Value Area Lines study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s209
Once that is set up on a 30 minute chart, use the Study/Price Overlay study which is documented here:
Study/Price Overlay Study
Here is an example:
http://www.sierrachart.com/image.php?l=1452163355117.png
The Chartbook for this is attached.
attachmentVolumePOCOverlayToDaily.cht - Attached On 2016-01-07 10:44:25 UTC - Size: 59.05 KB - 528 views
