Date/Time: Fri, 27 Dec 2024 15:53:20 +0000
data for replay
View Count: 716
[2016-01-05 07:17:00]
User844406 - Posts: 18
My SCH package 5 will expire in 2 days and I will extend it. I want to use only (not live) Historical Data for my replay and I would like to ask you how should I adjust SCH to use SCH data (tick).
I do not want to use data from Interactive Brokers (which is my broker).
How do I recognize which data I am using? (When I used live data from SCH there was [M] in the chart.
Thank you,
Daniel
[2016-01-05 09:47:25]
You just need to use the Sierra Chart Historical Data Service:
The instructions are on the page linked to above.
[2016-01-05 13:53:46]
I went through the link, but I haven´t found my answer.
I want to be sure, that I am using tick SCH data for Replay. Is it all I can do? Go to:
Global Settings - Allow Support for Sierra Chart Data Feeds
Global Settings - Service - Interactive Brokers (or do I need to change Service to SC Historical Data)? - in this case I think I will receive only minutes (not tick) data.
I found that Service should be changed from Interactive Brokers into SC Historical Intraday Futures Data to get tick data, but this option I haven´t found.
Thank you
[2016-01-05 15:41:31]
You must follow through the instructions on that page. Here they are:
https://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php#UsingSCHDS
You do need to set the Service to "SC Historical Data".
This is not true:
Date Time Of Last Edit: 2016-01-05 15:43:15
