Date/Time: Fri, 27 Dec 2024 15:56:09 +0000
OHLC study
View Count: 791
[2016-01-04 19:45:30] |
gmorgan111 - Posts: 121 |
I upgraded to the version 1344 which you said would fix the problem with the Close following the tick in each candle. The close is not fixed to the previous days close but still follows each tick as the candle is forming Thanks |
[2016-01-04 20:10:21] |
You are not running version 1346 which is the current version. Follow the instructions here to update: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate If there still is a problem we need to see an image of the chart. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-05 08:32:29] |
User13668 - Posts: 294 |
V1346 fixed the problem for me.
