Date/Time: Fri, 27 Dec 2024 16:33:52 +0000
Volume At Price Threshold Alert Subgraphs Draw Style
View Count: 873
[2016-01-04 17:42:12] |
kas64h - Posts: 87 |
Is it possible to have a Volume At Price Threshold Alert Study display the actual Bid or Ask Volume on the chart when the threshold is breached? Looking at the Draw Style under the Subgraphs Tab, I can see for example a 'Value of Subgraph' option, but this displays the actual price at which the alert fired, not the Bid or ask Volume. Is this possible within the system at present, or would I have to start looking at things like ACSIL (about which I know nothing at present)? Many Thanks.
[2016-01-04 18:48:06] |
Do you mean the Bid or Ask Volume at the price level? There is only the possibility to display current values. Not a value that existed at some point when the bar was forming. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-04 19:39:18] |
Yes, the Bid or Ask Volume within the bar, at the price at which the Volume at Price Threshold was triggered. So rather than marking the chart with a triangle, arrow or square etc., it would mark it with the Bid or Ask Volume that triggered the threshold. If this is not currently possible, should it be achievable through the use of ACSIL - i.e. creating my own?
[2016-01-04 20:00:52] |
But you can already see this just by looking at those values already displayed assuming you have set the Numbers Bars to display Bid Volume and Ask Volume with the Column # Numbers Bars Text Input setting. We cannot answer the second question because it is still not completely clear what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-04 20:41:30
