Date/Time: Fri, 27 Dec 2024 16:29:32 +0000
[User Discussion] - Toolbar functions grayed out cant click
View Count: 771
[2016-01-04 17:25:15] |
User268341 - Posts: 15 |
Hello, Randomly toolbar functions grayed out on the chart and tools options (left picture) cant click on the options. On the individual chart (right picture) it does work but i dont usually have menu on my charts. Thank you for your help |
[2016-01-04 18:43:15] |
What we see does make sense. On the menu for the main Sierra Chart window, there needs to be an active chart window for the Chart commands to be displayed. What we see is a Spreadsheet window active instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-04 18:46:37
