Date/Time: Fri, 27 Dec 2024 16:48:15 +0000
Chart DOM
View Count: 854
[2016-01-04 15:49:36]
User39772 - Posts: 311
Hello, I activated Current Trades Bid/AskVolume under Chart DOM Colums.
It looks like in the attached file. I seems that data overwrites itself,
so that the feature is more or less useless.
Any hints how this could be used in a meaningful way ?
Maybe it has sth. to do with the scaling, but even if I zoom into the
scaling (see e.g. AAPL) it looks like data get's overwritte.
Private File
[2016-01-04 18:17:09]
That feature may not work so well with a stock because of small variations with the prices that the stock trades at which are at a decimal position beyond .01.
[2016-01-04 19:47:30]
Thank you for that info.
Would it be possible to implement the feature for stocks in the following way:
All cumulated size between e.g. 108.80 and 108.81 are added to the sizes that
belong to 108.80 or 108.81 depending on wether they are closer to .80 or .81 ?
[2016-01-04 20:08:10]
We will look into this.
[2016-01-05 03:40:25]
We will solve this in the next release.
