Date/Time: Thu, 31 Oct 2024 10:13:02 +0000
End of trial, would like to get next 15 days.
View Count: 615
[2016-01-04 13:15:10] |
User704288 - Posts: 1 |
Hello, I just finished my 15 days of trial version of sierra chart. Unfortunately I spent more then half of trial time by installing the Windows to my Macbook (I had issues with bootcamp) so I used only a few days of trial version. I know, its my fault. I am asking you if you would give me another 15 days where I can get know the sierra closer and use the maximal potential. Thank you in advance, David Date Time Of Last Edit: 2016-01-04 18:08:00
[2016-01-04 13:56:40] |
SC Developer - David - Posts: 660 |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". |
