Date/Time: Thu, 31 Oct 2024 10:13:05 +0000
Cell J80 and J81 of “Spreadsheet System for Trading.”
View Count: 702
[2016-01-04 00:09:30]
User760942 - Posts: 120
Hi SC,
I’m trying to add a $250 TakeProfit and $250 StopLoss to “Spreadsheet System for Trading” via Cells J80 and J81.
It will be used to trade the futures symbol “ES” whose tick value is $12.50 per 0.25 points (meaning 5 points= $250)
I entered the number 5 into Cells J80 and J81, then ran a backtest against ES and the results showed $250 StopLosses and $250 TakeProfits. I then ran the backtest again (without changing anything, as far as I can tell) and the Stoplosses and Take Profits were completely diffrentd (they were random intervals of $12.50, usually between $12.50 and $100)
Any idea why this is happing?
I guess I may have changed a setting somewhere without realizng it, but can’t figure out how to change it back.
Thank you!
[2016-01-04 09:45:05]
These are Attached Orders. So therefore you need to make sure they are actually being used. Enable Use Attached Orders:
https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#AttachedOrderWindowInterface
Also, review the information here to understand how orders are filled:
https://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#HowOrdersAreFilled
Look at the fill prices and the trigger prices.
Date Time Of Last Edit: 2016-01-04 09:46:00
