Date/Time: Sat, 12 Sep 2026 19:56:52 +0000
Chart drawings
View Count: 944
| [2016-01-03 04:28:39] |
| User78188 - Posts: 10 |
I have the setting on a few of my charts to copy chart drawings. Is there a setting that allows the user to delete any chart drawing off of any chart? For example I add a horizontal line on chart 1 but when I try to remove it on another chart it won't allow me. I then have to find the chart a originally drew the line.
| [2016-01-03 08:11:27] |
You can only delete a Chart Drawing on the chart it was originally drawn on.
| [2016-01-04 01:16:57] |
It would be nice if this could be implemented in a future release.
| [2016-01-04 01:19:40] |
There are no plans for this.
