Date/Time: Thu, 10 Sep 2026 16:56:02 +0000
how to set a repeating alarm to a line.
View Count: 1199
| [2016-01-03 03:09:17] |
| User21339 - Posts: 61 |
i want to set a repeating alarm on a line. I draw the line then under line properties>options selecting 'A'. enable alarm with the parameters i want doesnt give a sound alert. I see under alertsounds in the sierracharts directory there are no Alert1-150 sound files. Do i need to asscotiate these somewhere? I read the alert setting for studies. and it looks very complicated and doesnt seem to apply to a single line. |
| [2016-01-04 03:14:31] |
The first step is to refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Alerts Chart Drawing Alerts are thoroughly documented. So you should be able to determine the reason for the problem by going through all of the steps. I see under alertsounds in the sierracharts directory there are no Alert1-150 sound files.
This does not matter.
