Date/Time: Fri, 27 Dec 2024 16:16:38 +0000
Polynomial regression channel cause crash when chart link with studies
View Count: 1143
[2016-01-02 16:44:08]
User380760 - Posts: 88
The following steps will reproduce the crash:
- start with clean chart
- link two charts together to sync the study
- add fibband, then apply study
- then add Polynomial regression channel, apply apply, then ok, crash
I believe the problem is with the polynomial regression channel. I have fibband on studies, never crashes with chart link or not. The polynomial regression channel also cause crash when fibband is not on study list.
[2016-01-02 23:55:00]
We are fixing this now. We now understand why this happens.
We have heard this once before about a similar problem but we did not know what the reason for it was and we got no further information from the user.
[2016-01-02 23:57:12]
Also, there is no need to use the "Apply" buttons on the chart studies windows if you intend to press the OK button immediately after. It causes unnecessary calculations.
[2016-01-03 08:17:29]
If you update to the latest release with Help >> Download Prerelease, you will get the revision that solves this problem.
[2016-01-04 20:34:09]
What is error cold 0060?
[2016-01-04 20:43:19]
What is this in reference to? We have no idea what you are referring to.
