Date/Time: Thu, 31 Oct 2024 10:13:06 +0000
Text display for study/from chart display request
View Count: 870
[2016-01-02 13:19:39] |
calitrader - Posts: 28 |
Can we have an additional color chooser added to these studies that would allow the BG color to be set to red or green based on auto coloring +/-? If I have a 20 period ema, I would like to have the BG set to red or green based on weather we are above/below the avg. If not maybe hardcode the text color to allow the auto coloring feature. Thank you. Chris |
[2016-01-04 09:42:49] |
You will need to create your own custom version. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
